Watchdog
A watchdog timer automatically resets the system if your application stops responding — useful as a safety net against firmware bugs, deadlocks, or peripheral hangs that would otherwise leave the device stuck. The watchdog counts down from a configured timeout, and your application must kick it periodically (Reset()) to prevent the count from reaching zero. If it reaches zero, the system reboots.
NuGet package: GHIElectronics.TinyCLR.Devices.Watchdog.
Once the watchdog is enabled, it cannot be disabled without a full system reset or power cycle. Plan the timeout carefully before enabling.
Don't enable the watchdog while step-debugging — the system will reset every time you pause on a breakpoint. Either disable the call during development or wrap it in a debug-vs-release conditional.
Basic usage​
Run the watchdog in its own thread so the timeout is independent of what your main loop is doing. The example below sets a 5-second timeout and kicks the watchdog every 4 seconds — giving the system a 1-second margin before it would reset.
using GHIElectronics.TinyCLR.Devices.Watchdog;
new Thread(RunWatchdog).Start();
void RunWatchdog() {
var watchdog = WatchdogController.GetDefault();
watchdog.Enable(5000); // 5-second timeout.
watchdog.Reset(); // Kick the watchdog.
Thread.Sleep(4000); // Run again before the timeout expires.
Picking a timeout​
The timeout has to be longer than the worst-case time between kicks, or you'll false-trip and reboot in normal operation. Things that affect this:
  • Worst-case work in the kicking thread between Reset() calls
  • GC pauses (occasional, hundreds of ms in heavy workloads)
  • Slow blocking operations (file I/O, network requests)
A common pattern is to set the timeout to roughly 2× your steady-state kick interval so transient delays don't trip it, but real hangs do.
If you set it too short, the device gets stuck in a reset loop. If you set it too long, the system might be unresponsive for a long time before recovering. Tune to your application's responsiveness budget.
GHIElectronics.TinyCLR.Devices.WatchdogWatchdog timer controller classes
