Secure Boot
Secure boot is the foundation of TinyCLR's security model. Every layer in the boot chain verifies the next, so by the time your application runs, you have a strong guarantee that nothing tampered-with has been loaded along the way.
The chain of trust​
A SITCore device boots in three stages, each verifying the one above it:
  1. Boot ROM — burned into the SITCore at manufacturing, lives in internal memory that isn't externally accessible. Verifies the bootloader's signature before running it.
  2. GHI Bootloader — handles firmware loading, recovery, and TinyCLR Config communications. Cryptographically signed by GHI Electronics. The boot ROM refuses to run it if the signature doesn't match.
  3. TinyCLR Firmware — the .NET runtime. Also signed by GHI Electronics. The bootloader refuses to run unauthenticated firmware.
Once TinyCLR is running, your application loads from the deployment region — protected by IP Protection and Secure Storage for runtime data.
What this gets you​
  • Tamper detection — a modified bootloader or firmware fails its signature check and the device refuses to boot.
  • No external code execution — there's no path for code that isn't signed by GHI to run on the device, even with physical access.
  • Defense in depth — combined with IP Protection (protects your application code at rest) and encrypted In-Field Update (protects firmware updates in transit), the device is closed from end to end.
What this doesn't cover​
Secure boot protects the boot chain itself. It doesn't automatically protect:
  • Application secrets — keys and credentials baked into your application code. Use Secure Storage for runtime secrets.
  • Network traffic — encrypted separately by TLS.
  • External memory — data in external SDRAM and QSPI flash can still be physically probed. Use IP Protection's Secure Assemblies for code stored externally, and keep sensitive data inside the SITCore's internal memory.
