Font Support
Fonts on TinyCLR are stored in a custom .tcfnt binary format. Any TrueType font can be converted to .tcfnt with the FontConverter tool, embedded as a project resource, and used by the graphics engine for drawing text.
Old NETMF font files don't work on TinyCLR — re-convert with the current FontConverter even if you have older .tinyfnt files lying around.
NuGet package: GHIElectronics.TinyCLR.UI (the graphics engine that draws text). The FontConverter itself is a separate command-line tool available on the Downloads page.
Using a font​
Load the converted font as a resource and pass it to the graphics engine:
using GHIElectronics.TinyCLR.UI;
var screen = Graphics.FromHdc(displayController.Hdc);
var font = Resources.GetFont(Resources.FontResources.NinaB);
var greenPen = new Pen(Color.Green);
screen.DrawString("Hello World!", font, greenPen.Brush, 10, 100);
screen.Flush();
See Graphics for the rest of the drawing API.
Converting a font​
Converting a TrueType font to .tcfnt is a two-step process:
  1. Write a .fntdef file — a plain-text descriptor for the font: which face, which sizes, which character ranges, etc.
  2. Run the FontConverter — produces a .tcfnt file you embed as a resource.
A minimal .fntdef for the standard ASCII range:
SelectFont "FN:Arial,WE:400,HE:12,IT:0"
ImportRange 32 126
Run the converter:
GHIElectronics.TinyCLR.FontConverter.exe Arial.fntdef Arial.tcfnt
The TinyFont Tool is a third-party GUI that can also generate compatible font files if you'd rather not write .fntdef files by hand.
.fntdef reference​
The order of statements matters — for example, AntiAlias must come before the ImportRange it should apply to.
Font selection​
AddFontToProcess path​
Include a TrueType font file in the search list, in addition to the system-installed fonts. If the path contains spaces, quote it and escape backslashes.
AddFontToProcess C:\Windows\Fonts\Arial.ttf
SelectFont "selection string"​
Search the available fonts for the first one matching the comma-delimited fields in the selection string. No spaces around commas or colons — they cause parse errors.
FieldMeaning
HEHeight in logical units. 0 for default; positive = cell height; negative = character height.
WIAverage character width in logical units. 0 for best aspect-ratio match.
ESEscapement angle in tenths of a degree. Negative = clockwise rotation.
WEWeight (0–1000). 400 = normal, 700 = bold. 0 for default.
ITItalic — IT:1 enables italic.
FNFace name (typeface name).
FullNameFull font name, e.g. "Monotype:Arial Regular (Microsoft)".
Example — regular-weight Arial at height 12:
SelectFont "HE:12,WE:400,FN:Arial"
Character ranges​
ImportRange start end​
Unicode code points to include, inclusive. Both arguments required. Use multiple ImportRange statements to convert non-contiguous ranges. Must come after SelectFont.
ImportRangeAndMap start end offset​
Same as ImportRange, but maps the imported characters into a different range — output characters land at start + offset through end + offset. Must come after SelectFont.
SetAsDefaultCharacter charcode​
Sets the Unicode code point used as a substitute for any character not in an imported range. Must come after SelectFont.
SetDefaultCharacter​
Use the currently-selected TrueType font's own default character as the substitute. Must come after SelectFont.
NoDefaultCharacter​
Don't substitute anything for unconverted characters. Must come after SelectFont.
Anti-aliasing​
AntiAlias level​
Levels 1, 2, 4, or 8 produce 2, 5, 17, or 65 levels of gray in the output bitmap respectively. Must come after SelectFont and before any ImportRange it should apply to.
Position adjustments​
All of these take an integer (positive or negative). The Adjust* family applies to EM units unless noted; OffsetX / OffsetY apply to subsequent character ranges.
StatementEffect
AdjustAscentEM units added to ascent. Once per file.
AdjustDescentEM units added to descent. Once per file.
AdjustExternalLeadingEM units added to external leading. Once per file.
AdjustInternalLeadingEM units added to internal leading. Once per file.
AdjustLeftMarginDevice units added to left margin. Applies to the next ImportRange.
AdjustRightMarginEM units added to right margin. Applies to the next ImportRange.
OffsetXEM units to shift left (positive) or right (negative). Applies to subsequent ranges.
OffsetYEM units to shift down (positive) or up (negative). Applies to subsequent ranges.
Other​
Verbosity level​
Not currently supported — set to 0.
# comments​
Lines starting with # are comments.
# This font is used by the main menu.
SelectFont "FN:Arial,WE:400,HE:14"
ImportRange 32 126
GHIElectronics.TinyCLR.UITinyCLR UI framework (fonts, controls, layout)
