Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
GHIElectronics.com
Home
Help
Search
Login
Register
GHI Electronics LLC
.NET Micro Framework Devices
Embedded Master
question about your advice: moving to EMX
Pages: [
1
« previous
next »
Print
Author
Topic: question about your advice: moving to EMX (Read 333 times)
EVS
Jr. Member
on:
March 10, 2010, 11:15:58 AM »
Hi, about your message "Although this module is in full production and will not be discontinued anytime soon, we highly recommend using EMX Module instead. "
I want to ask you: why do you suggest to move to the new device?
We have already created a board based on Embedded Master Module, are the module compatible for connections and dimensions?
Thanks in advance.
Logged
SupportAdmin
Administrator
Hero Member
Re: question about your advice: moving to EMX
Reply #1 on:
March 10, 2010, 11:33:03 AM »
Many reason, starting with double RAM and USB boot loader and having LCD pins easily exposed....plus RLP and other things that may come!
At some point in future, we will discontinue Embedded Master and EMX will be the replacement. This will be couple years (or more) from now so you do not have to worry about it anytime soon but as soon as you have a chance to move to EMX then you should do it.
In other words, we are giving you few years to change your design from Embedded Master to EMX. There is no rush but you must do that at some point.
Logged
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
=> General Discussion
=> ChipworkX
=> EMX
=> Embedded Master
=> USBizi
FAT File System Chipsets and OEM Boards
=> uALFAT
=> USBwiz
Loading...
