Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
GHIElectronics.com
Home
Help
Search
Login
Register
GHI Electronics LLC
.NET Micro Framework Devices
General Discussion
Power Cycle When Debugging
Pages: [
1
« previous
next »
Print
Author
Topic: Power Cycle When Debugging (Read 303 times)
MarkB
Newbie
on:
February 27, 2010, 02:38:30 PM »
When I am uploading changes of our solution while debugging it very often occurs that we need to power cycle or reset our hardware. When the solution was smaller this occurred but much more infrequently has anyone any ideas as to what is happening.
The hardware platform is based on the USBizi chip and the hardware had been designed by our group.
Logged
SupportAdmin
Administrator
Hero Member
Re: Power Cycle When Debugging
Reply #1 on:
February 27, 2010, 03:14:48 PM »
Are you using 4.0 yet? If not then you should if you can
Logged
MarkB
Newbie
Reply #2 on:
February 28, 2010, 07:21:15 PM »
What I understand from this statement is that yes MFW3.0 has this problem as a known issue and that MFW4.0 fixes this problem?
If this is the case how much different are the libraries because I have quite a bit of code written for this project. I don’t expect it to be too big a change but I am now thinking about my schedule.
Thanks for the help
MarkB
Logged
SupportAdmin
Administrator
Hero Member
Reply #3 on:
February 28, 2010, 07:41:02 PM »
There is no major known issues with 3.0 but I noticed that 4.0 is much more solid.
The move from 3.0 to 4.0 should be easy but remember that current 4.0 release is still in beta
Logged
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
=> General Discussion
=> ChipworkX
=> EMX
=> Embedded Master
=> USBizi
FAT File System Chipsets and OEM Boards
=> uALFAT
=> USBwiz
Loading...
