Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Pages: [1]
  Print
Author Topic: Changing default IOs for ZeroG WiFi Module  (Read 299 times)
nvillar
Newbie
View Profile
« on: February 16, 2010, 01:18:57 PM »
I need to be able to change the default SPI interface and IOs used by the ZergoG module. Ideally, I'd like to be able to use either SPI1 or SPI2, but the critical thing for me is to be able to use either E1/E16/E19 instead of E28 for SSEL.
I notice that there is a SetZG2100Interface method, which is marked as 'not supported yet' in the documentation. This would be ideal. Is there any other way to access this functionality at this time?
Thanks in advance.
« Last Edit: February 16, 2010, 01:42:20 PM by nvillar » Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #1 on: February 16, 2010, 01:53:03 PM »
This and many other things will come in 4.0 this month
Logged
support
Administrator
Sr. Member
View Profile
« Reply #2 on: February 17, 2010, 10:18:49 AM »
Actually SetZG2100Interface Method is already implemented in the current firmware version 3.3.0.
We are sorry that the documentation was not updated accordingly. you can change ZG2100 interfaces to any pins. taking into consideration that the ExtInt Pin should be assigned to a GPIO with Interrupt feature.
« Last Edit: April 26, 2010, 04:51:55 PM by SupportAdmin » Logged
Pages: [1]
  Print
Jump to:
