Hello and thanks for response. The Garmin works on my PC when I assign a virtual COM port to it using Franson GpsGate 2.6 but I have not had any luck communicating to it via USBwiz with any of the serial classes at least using the 'Serial device test'. However, this might me due to the fact that 'Serial device test' only gives me three options for baudrate (2400, 9600, 115200) and the Garmin uses 4800. I should try modify the USBwiz firmware to include 4800 baudrate. Perhaps I will try that today.
On another note, I was able to connect to the GPS 18 using the RAW commands but so far no luck getting any data out of it but this is probably due to my inexperience with the USB protocol which I only started studying last week. Perhaps you can give me a sequence of RAW commands that I can use to start the communication based on Garmins commprotocol which can be found here
http://www8.garmin.com/support/commProtocol.html I will keep trying on my end to establish communication using either serial classes (with appropriate baudrate 4800) or RAW commands. I will update this post if/when I make any progress.
First, see if Garmin works as a serial port on your PC. If it does, chances is that it works fine on USBwiz with our serial classes (Prolific, FTDI, Silabs, CDC).
If not, this might not be easy. you have to know somewhat about USB in general. Then use USBwiz raw USB commands to communicate with your device. You will understand these commands if you take a look at USB specs.
