Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Pages: [1]
  Print
Author Topic: DHCP and Debugging  (Read 2917 times)
Osbornaldo
Newbie
View Profile
« on: April 30, 2009, 10:55:01 AM »
Hey Chaps,
I've been making some great progress with my efforts to develop for the MF against the GHI Embedded Master board and so far it's a positive experience! However enabling DHCP on my device is preventing me from debugging my application...
I have:
  • Enabled DHCP using the MFDeploy's Target > Configuration > Network menu.
  • Manually Set My MAC Address to the 00:21:03:80:00:xx specification
I then reboot my device into debug mode and deploy my application from Visual Studio over serial port as normal - but whilst my application deploys and executes fine - I loose debugging capabilities.
What am I missing?
Logged
GHI_Support
Administrator
Hero Member
View Profile
« Reply #1 on: April 30, 2009, 11:25:39 AM »
So it works fine if you did not enable DHCP but used static IP?
What Happens if debug in visual studio? It just exists and the application starts?
What do you see on the debug output (serial port), if you reboot the device?
Logged
Osbornaldo
Newbie
View Profile
« Reply #2 on: May 01, 2009, 04:06:50 AM »
It works fine with the default board settings (DHCP disabled).
I can run my application from visual studio and it will deploy onto the board (over COM1) and engage the debugger.
When I enable DHCP the board does pick up an IP address from our server (though it takes about 5 seconds to do it) - so DHCP seems to work fine.
I then reboot my board into debug over COM1 as I usually do and try to run my application from visual studio.
The application is pushed out to the board and begins to execute but Visual Studio seems to loose connection with the board (it exits debug mode).
I've seen mention on the forums about debugging over TCP/IP - would that help?
If so - how do I achieve this?
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #3 on: May 01, 2009, 07:12:40 AM »
You can debug using serial and keep DHCP enabled. The problem is the device is taking a long time to get an IP and so VS2008 is timing-out.
The text below from the Microsoft micro framework forum
Quote
Issue:
After deploying an application from Visual Studio, the device is rebooted.
In
some cases, DHCP can cause Visual Studio to time out while waiting for a
reconnect, preventing Visual Studio from debugging the device.
Resolution:
Add a registry key and value to increase the amount of time Visual Studio
will
wait for a reconnect. The default of 5 seconds may be extended by creating
the
following key and setting its timeout, retries, and override values:
HKCurrentUser\
Software\
Microsoft\
.NetMicroFramework\
NonVersionSpecific\
Timing\
AnyDevice
'timeout' (DWORD): milliseconds to wait before retrying
(constrained to 50 < timeout < 60000)
'retries' (DWORD): count of retries to attempt
(constrained to 1 < retries < 1000)
'override' (DWORD): if present and non-zero, ignore constraints above,
and attempt to apply any valid DWORD values.
If any one of the values provided is out of bounds or malformed, it is
silently ignored and the default values remain in effect. However, the
others
that are valid are still be applied.
The default values are as in v2 SP1: timeout = 100 for platforms that
support
a soft reboot, 1000 otherwise; retries = 10.
Logged
Osbornaldo
Newbie
View Profile
« Reply #4 on: May 01, 2009, 11:28:08 AM »
Thanks again for you help - that worked great.
So far am very impressed with the support offered on this forum.
Particularly when you consider this problem was more of a general MF/Visual Studio issue than anything to do with GHI.
Thanks again!
Logged
microt
Full Member
View Profile WWW
« Reply #5 on: May 17, 2009, 07:48:52 PM »
•Enabled DHCP using the MFDeploy's Target > Configuration > Network menu.
Works great
But how do I do it from the code
I tried EnableDHCP(); at start up
Error   1   The name 'EnableDHCP' does not exist in the current context   C:\Installs\MSVC#\Test\Test_01\Test_01\Program.cs   66   13   Test_01
What am I missing
« Last Edit: May 20, 2009, 01:03:04 PM by microt » Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #6 on: May 20, 2009, 01:41:42 PM »
These questions are best answered by the Microsoft forum for Micro Framework
The function is
NetworkInterface.EnableDhcp()
Logged
lbq1221119
Newbie
View Profile
« Reply #7 on: May 21, 2009, 03:13:12 AM »
i have the same problem as above,
and when i look into register,
i can not find
HKCurrentUser\
Software\
Microsoft\
.NetMicroFramework\
NonVersionSpecific\
Timing\
AnyDevice
there is not a NetMicroFramework under Microsoft.
do i missing something?
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #8 on: May 21, 2009, 11:02:27 AM »
Maybe they removed it or moved it?! Again, this question is better answered by Microsoft
Logged
sutsch
Newbie
View Profile
« Reply #9 on: May 22, 2009, 02:08:15 PM »
If the entries are not there just add them! Work like a charm! :-)
Logged
microt
Full Member
View Profile WWW
« Reply #10 on: June 25, 2009, 11:32:17 PM »
Using 3.0
Tried enabling DHCP using the MFDeploy's Target > Configuration > Network menu.
Error: Unable to update configuration sector memory
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #11 on: June 26, 2009, 09:14:39 AM »
Reload the firmware as the configuration could be corrupted. Also, enter TinyBooter before trying to update
Logged
microt
Full Member
View Profile WWW
« Reply #12 on: June 30, 2009, 04:12:00 PM »
Since there is lot of delay if DCHP is enabled..and there is a blank screen..is there a better way of doing this?
-Start of with a static IP <or> not TCP/IP. So the system comes up fast..
-Once the system is up and running..from the Applicaiton software..Print "DHCP enabled..getting new IP" on the LCD
-Then enable TCPIP & DHCP and time out if DHCP does not work, so the applicaion can and go to a static IP
Logged
GHI_Support
Administrator
Hero Member
View Profile
« Reply #13 on: June 30, 2009, 04:41:03 PM »
Yes, you can do this in your software.
Also, the screen is not blank, we do print getting Ip address when DHCP is enabled! unless you disabled debug messages.
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #14 on: June 30, 2009, 08:23:45 PM »
I think once you enable DHCP in software then it gets saved in flash and so next time you power up the device it will still wait for an IP address.
This problem was reported to Microsoft long time ago! Maybe future release will handle DHCP better
Logged
Pages: [1]
  Print
Jump to:
