First of all in the last days i have written lot of programs for usbizi and i think that is absolutely fantastic!!! Great Work!!
After getting confident with usbizi and the way that reacts to different programs it was time to write a real program. I am working in a company that develops different products for the industrial sector, one of our problems is that almost all of our projects use seral ports and we have not found any EASY way of using USB instead. In microsoft .net micro framework 3 i have seen an example of a device that acts as a usb mouse.
1) Is there any way to program the usb port to act as a serial port when plugged to a pc, and if it is what baud rate i will be able to obtain?
2) Is there any way when the device is plugged in the pc to have access from the pc to the SD and then read the sd from the usbizi, (not simultaneously, because i know that this is not possible)
3) (desperate queston
) Is there any other way to send to the device data other than that thru the USB (without the need to write a driver in windows)?
Thanks in advance and keep up the Great Work
Iliopoulos Dimitris
