Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Pages: [1]
  Print
Author Topic: uALFAT very slow to respond or not responding at all  (Read 3061 times)
RichardGunn
Newbie
View Profile
« on: August 05, 2008, 10:34:28 AM »
I have just started working with my first uALFAT. I have it connected, in UART mode, to Hyperterminal and successfully got the Boot Loader (V2.03) to program the firmware V3.11, receiving a response of !00.
However, now I have fitted the link to allow the uALFAT out of the Boot Loader, it is not responding to commands at 9600Baud much. After several minutes, I got a start-up message out of it and have got the version using the V command, but it all seems to take forever, if it responds at all.
I am NOT using the RTC crystal and the Vbat pin is tied to the 3.3V supply.
Any ideas what I am doing wrong?
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #1 on: August 05, 2008, 10:37:18 AM »
What is connected to CTS? This is explained in the manual very clearly.....if CTS is not low then uALFAT will not respond Wink
Logged
RichardGunn
Newbie
View Profile
« Reply #2 on: August 05, 2008, 10:46:14 AM »
Sorry, CTS is at 0V, it is controlled by another microcontroller but it is currently always low.
Logged
SupportAdmin
Administrator
Hero Member
View Profile WWW
« Reply #3 on: August 05, 2008, 10:51:58 AM »
So is it working now?
Logged
RichardGunn
Newbie
View Profile
« Reply #4 on: August 05, 2008, 11:01:31 AM »
Well yes and no, it works when you put a scope probe on the CTS pin or on the microcontroller pin which drives it; the pin always looks low on the scope but it is obviously floating. It must be a problem with the set-up of the other microcontroller. Thanks for pointing me in the right direction.
Richard Gunn
Logged
orion
Newbie
View Profile
« Reply #5 on: February 11, 2009, 12:43:53 AM »
hii..
I am working on the uALFAT SD module and am trying to connect it with the hyper terminal of the PC.
after the connections were made the letter L appeared on the PC screen.
Whereas the response should have been BL right ?
the following are the connections:(of the MMC module)
pin 1        TX USART
pin 2        RX USART
pin 7        CTS  ground
pin 5, 8    ground (SPI_SSEL# , SPI_SCK)..for USART mode.
pin 12       VBAT 3.3V
pin 13      VCC 3.3V
pin 15      ground
I even tried sending V for the version number but there is no response.
Are there any other critical connections to be made?
on the PC side( DB 9 connector) I have connected its pins ( 2, 3 ) to RS232 pins ( 14 and 13 ) respectively and pin 5 of DB9 is grounded.
« Last Edit: February 11, 2009, 12:46:00 AM by orion » Logged
GHI_Support
Administrator
Hero Member
View Profile
« Reply #6 on: February 11, 2009, 10:10:45 AM »
are connection direct from uALFAT to your PC? You shouldn't do this, you need something like MAX3232 to convert the voltage signals.
Logged
orion
Newbie
View Profile
« Reply #7 on: February 12, 2009, 03:55:34 PM »
yes there is a max232...between DB9 connector and the module...
and today I again tried...it returned the the model number (automatically)after powering ON the circuit...
then i tried sending or receiving files...nothing was happenning....
for once it showed " !00" (i.e indicating it is ready to accept the next command)...but then it showed no response to any furthur action from my side...
there was another doubt I had regarding the protocol we use to receive data from the MMC card to the PC...the options were like...X1modem, Y modem, Z ..with crash recovery... what are these and which one should I use...
thanks..
« Last Edit: February 12, 2009, 03:57:05 PM by orion » Logged
GHI_Support
Administrator
Hero Member
View Profile
« Reply #8 on: February 12, 2009, 05:20:27 PM »
you cannot send/receive files. uALFAT works with commands... See user manual. And on PC you should have 9600 baud 8N1 settings.
Logged
Pages: [1]
  Print
Jump to:
